Where did you hear this?
The government doesn't "guarantee" any money unless they are explicitly funding a development effort.
Obtaining FAA certification on an "engine" is relatively simple. Obtaining the PMA certificate (production manufacturing) is an entirely different animal PMA kills 80% of all certification efforts. And THEN one must obtain a certification for the "combinations", i.e. prop/engine/airframe INCLUDING flutter and vibration testing. VERY costly and VERY time consuming. "Combo" certification kills 99% of all FAA certification efforts.
Despite the hype, there are very few UAV's flying compared to Experimental aircraft. Total flying UAV population is measured in "hundreds" worldwide.
With the demise of Thielert, a certificated diesel UAV won't be coming to a dealer near you anytime soon.
If DH were smart (no evidence yet) they would get an RV flying, fly the **** out of it (3000hours) and THEN market the engine. Forget FAA.
So, I take it there isn't a Delta Hawk engine in any RV yet?
I'm sorry to say that Deltahawk is starting to look a lot like Zoche.
Their SFC claims vary between .35 and .38 depending on the info you look at- only slightly better than a modern Lyco with FI and EI. DH should come clean on this stuff.
0.35 for SFC for a two stroke diesel with mechanical injection is hard to beleive; The Thielert FADEC 4 stroke was about at that figure;
Further, the 2 strokes generally have the optimum SFC over a very narrow RPM/Power range; 4 strokes are pretty much constant over all of the RPM/power range.
I still don't buy the limited operating point of the two-stroke. Take the WAM-120 as an example. It operates an economy cruise BSFC of 0.43 at 2300 to a rated T/O power BSFC of 0.49 at 2700. That's neither an enormous spread of BSFC, nor a narrow operating window - in fact it's just what you want for direct drive. The numbers don't look that spectacular (it's IDI and uniflow scavenged - i.e. valvegear!) but in the real world they translate into pretty impressive fuel burn rates. A DI version would be another leap forward again.
A flat SFC curve is a dubious advantage when you pay significantly for it in installed power/weight ratio, which both TAE and SMA do - badly enough to make them commercially suspect.
Well, we spend most of our time in cruise and the 2 stroke Diesels don't show an useful advantage over a good IO Lycoming there. If we look at what Klaus Savier is doing with a Conti O-200, I'm not impressed by any flying aero Diesel yet.
A good 4 stroke Diesel might be the ticket- if anyone ever develops one and keeps the weight down and cost. The turbo at least gives some more TAS up high.
I talked to Klaus at Reno last week and not only is the plane slick, the engine may be the most efficient gasoline engine flying today with the internal and EFI/ EI mods he has done. He is WAY more efficient than any other EZE flying and I'd make a bold guess that SFC is somewhat below .36.
A lightweight Diesel would be hard pressed to match his numbers IMO.
LightSpeed said:On Monday April 7th, just prior to Sun ?N Fun, the weather looked great for a non-stop flight across the country, coast to coast, 2000 miles. I hopped in the Delaminator as early as I could bear and set out for Florida. The tailwinds were good but not quite as strong as predicted so I had to slow down a little to increase my range. It took 8 hrs and 58 min for the total distance of 1985 statute miles, SZP, CA to PFN, FL via ELP TX to avoid the restricted area.
Total fuel used was 25.8 gallons of the 29.2 carried in the standard tanks, leaving more than an hour worth of fuel remaining. Average fuel flow for the entire flight was 2.87 gph. Average speed was 220.6 mph. Tailwind average was around 30 mph at 17500 ft. The density altitude was above 19000 ft. Of course, I was on oxygen for the entire flight.
JETA4GA,
You can read about the flight on the LightSpeed web site.
Here's the link:
http://www.lightspeedengineering.com/News/News.htm
Here's the Reader's Digest version:
Typically best SFC numbers are not at TO power on aircraft engines. The TC Wrights and Conti 550s running LOP are around .375 in cruise. Lycoming may be in these ranges soon with the introduction of their new IE2 engines/ FADEC system.
No way the current crop of Subaru engines would be anywhere close to what Klaus is getting with his O-200. Figures from Fuji put their best engines at no better than .42 in a very narrow rpm range, well below anything useful for aviation applications. Some of the new DI gasoline engines from Toyota, GM and BMW have just broken the .40 range.
Sorry to say there are NO aero Diesels being flown today which have accumulated enough real world flight time to demonstrate real 2000-3000 hour TBOs.
IMO it will be some time before any aero Diesel with comparable power to weight ratios to current Lycoming type gasoline engines, demonstrates these sort of TBOs in real life. Heavy ground based Diesels, yes, lightweight aero Diesels no.
Certainly the Thielert was an economic disaster with engines costing twice to 3 times that of a traditional aero engine, gearbox inspections every few hundred hours and most falling woefully short of their TBRs with a wide range of serious problems.
People are naive to think that aero Diesels will automatically duplicate the reliability of heavy ground based designs. The high continuous power settings required for aviation prime movers and the requisite high boost pressures that Diesels must run to achieve these put their longevity in question, especially in the exhaust valve and piston/ring departments. Most ground Diesels actually operate most of their lives at relatively low specific outputs.
I think the time will come but it is not here yet.
wrt the cost of the TAE engines, all I can say is that their OEM prices were substantially lower than those of the Lycomings and Continentals, not 3 times. You are probably referring to the retrofit FWF Kits with STCs that have to charge for a lot of installation NRE and a lot more installation parts and a/c Mods.
FG
As you know the SFC of Diesels are fairly constant over the idle-TO power range
clearly this is not the case, since at idle the BSFC is by definition, infinite, a divide by zero error, or whichever way you wish to look at it.
BSFC always degrades with decreasing load. On a gasoline engine, it does this much more quickly due to the increase in pumping work and deviation from optimal compression ratio. Running lean mitigates this to an extent, but you run into the lean combustible limit at some point and must throttle to reduce load further.
Clearly to me at least, Thielert was selling these engines to Diamond well below the cost to manufacture them to hook them and promote them. There is simply no way these could be made in these quantities at the OEM prices given the complexity of the design and development costs.
Furthermore, 2 minutes with a calculator dividing the reported $250-300 million R&D costs on the 1.8 engine alone by the numbers sold to Diamond for the prices asked along with the massive numbers of warranty replacement engines and parts showed this exercise to be a big money loser and this did not include what must have been huge additional costs to develop and test the 2.0 and 4.0 engines. The "new" prices for 2.0 engines are probably what Thielert needed to be selling the 1.8 engines to Diamond for in the first place.
SMA is maybe pricing their engines realistically to make it a viable business and they are well in excess of comparable Lycoming and Continental engines.
The fact is today to develop and certify a new engine design, costs tens of millions typically (or hundreds), without military sales where price is not really important, per unit commercial cost is likely to be far higher than established designs from decades ago where R&D, certification and tooling costs were paid for long ago.
The Thielert deal was hyped to the max by the press and never delved into much on a real world or economic level until their collapse. It was all gee whiz- look at how cool this is. The reality for operators was far different. The engines were a costly disaster for Diamond owners.
Hopefully buyers have learned something from all this. Wait until these engines are developed and proven for a few years first before you commit. An engine that burns 20% less fuel but costs twice as much to buy in the first place and requires more maintenance is no bargain, especially when the company goes bankrupt.
I applaud new engine development as you know but the economic realities of this often overshadow the enthusiasm of the technical work. Wanting to believe in something new to be wonderful does not make it so.
It will be a long time before Deltahawk investors get their money back and they are at least going the smart way with military interest.
Statements at the 2007 SAE World Congress said that with technologies such as BMWs Valvetronic and DI, gasoline engines were poised to soon be close to par for SFCs to Diesel designs and a great future was seen there. Indeed, we see this today with substantial fuel economy gains using these technologies. The gap is closing rapidly on Diesel vs. gasoline SFCs in the automotive world.
All I'm saying is aero Diesel proponents have a lot to prove before I'll accept it as reality.
As for any products, the tenacity and vision of the developers are what makes this world to reach new milestones and achieve progress.
FG
The wilksh airmotive diesel is interesting also but different from Deltahawk. The Deltahawk is US and starts at 160 hp. It also is turbo/supercharged and retails for $23,500 USD.
www.Deltahawkengines.com
Correct me if I'm wrong but I don't believe that there even one customer Deltahawk engine flying.
No problem, it was a very interesting piece. And that whole interview series is excellent, I'm glad I found it. What a treat to hear Frank Borman talk about his first hairy crosswind landing!
But anyway, I'm spoiled rotten on information in this age so it feels strange that there isn't more information on the engine available. Might as well gather all the good bits in this thread. I'm pretty sure I've read every publication and every forum post about it. Deltahawk has been saying "we'll have an engine ready this year" for many years, when that "promise" goes undelivered it can only hurt their reputation.
But it's a sound design and I think it will be a good product. It'll be ready when it's ready. I know I'm not building anything for a few years still, so patience is a cheap virtue for me.
Her ya go Ross
Ask and you shall receive.
http://www.youtube.com/watch?v=YWP-HocpvPA&feature=related
Its from 2003. I certainly don't have a horse in the race but this couples stick-to-it-ness is admirable to say the least. There is lots of new Deltahawk info out but you just have to search for it unfortunately. From what I have read recently it looks as though the certification process is ongoing and that a TC is expected sometime early 2011. Heh but what do I know? I thought Verizon would have the I-phone this Fall. All the best.
I'm not sure I'd call anything unproven a sound design.
