  #81
Old 03-26-2020, 08:35 AM
EXTAAFLY EXTAAFLY is offline
Originally Posted by scsmith View Post
Yes, just the four outboard gear bolts that go through the U803 saddles.
Not 240 ft-lbs of torque though! 8^O
Feet, Inches, Nanometers, they're all the same right? It's just the quantity that counts!
A quick review of the plans, it is 240 INCH-LBS.
I am assuming with this hardware it's the same. Anybody retrofitted from a completed airplane? How much "fun" was it?
Thanks!
Jason
ATP - CFII/MEI
RV8 - Adoption Complete / Beautification in Progress
RV14A Build/Kit - SOLD
12/02/19 Donated
Old 03-26-2020, 08:45 AM
Kahuna's Avatar
Kahuna Kahuna is offline
FWIW, mine (replaced nuts) have not budged in years and I likely have the heaviest repeat load tests on the plane being a Super 8 with 84gal of fuel. There is no question that after the stock nuts, replaced a few times, kept loosening, this is fixed.
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 03-26-2020, 09:45 AM
PhatRV PhatRV is offline
After reading all these posts, I ordered 4 NAS nuts from Aircraft Spruce. They are not cheap but insurance will cost some money. I haven't mounted the gear yet but I like the idea that I only have to torgue these nuts once and they should be tight for years.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Interior work
Donation paid through 2020
Old 03-26-2020, 12:17 PM
riseric's Avatar
riseric riseric is offline
Even if these nuts stay put, don't forget to (as per Van's instructions):
"Check these bolts and re-torqued after the first ten flying hours, then again
at 50 hours, and annually thereafter. Failure to do so could lead to premature wear."
Eric,
2020 dues paid
RV-8 nį 83274
Empennage done & on fuselage (glass to finish)
SB Wings done (fitted to fuselage)
SB Fuselage in progress (wiring 90%, panel next)
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro, EFII System 32 & Bus Manager
AFS 5600, Dynon DA10A,
Aerosport IO-375, MTV-9-B/183
Old 03-26-2020, 08:25 PM
Blain's Avatar
Blain Blain is offline
I canít remember the details but I replaced the bolts with the next longer to get the required thread protrusion.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2020(my reminder)
Old 03-27-2020, 06:25 AM
Daida Daida is offline
Thanks!
Mine is not flying yet, but should be within the next 4 weeks (depending on the Virus-Thing development).
However, whilst fully assembled (and standing on the gear) i switched to longer bolts and the stronger nuts. That wasn´t a Problem at all as the gearlegs are hold in place by the single big bolt and the U-804 inboard main gear attach bracket. The aircrafts weight actually pushes the U-801-L/R gear leg firmly against the U-805-1 outb wear plate.
I removed one bolt at a time and replaced with the new Hardware thightened them and torqued them when both bolts&nuts where replaced on the same side.
No biggy, if you neglect that i do not have the tower mods done. You need two persons though.
Just make shure that the Aircraft is unable to move while you are on it.
I put mine in Level-flight attitude (put the tail on a sawhorse) to have the load of the gear coming in perpendicular onto the U-805-1 outb wear plate.
One might argue that the torque value is not correct because the whole assembly is pre-loaded……….i did it anyways and will re-check after taxi tasts have been completed, after 10 and 50 Hours and then annually.
RV-8 QB Germany
metal work complete
ECi XIO-360 installed
Dynon SV
Wings+Empenage+Fuselage=Plane
Final touches....
Almost there!
