DCSchmiesing
I'm New Here
I was most interested in Steve Smith's tests on landing gear nuts and bolts! 220 hours since completion 2004 on my RV-8 QB. I'm not a hamfisted pilot and I annually inspected my RV-8 gear tower and torqued the bolts faithfully. (I'm very careful about not over-torquing.) Sure, I've had some bounces, but nothing spectacular. At my last annual inspection, before torquing the gear tower bolts, I jacked up the left gear to rotate the tire. To my surprise, the gear leg was not rigid, but would rotate backward 5 degrees easily. I have the Grove gear (non-aerodynamic). I looked in the left gear tower and saw the front MS21042-6 nut totally off the bolt and sitting by itself in a corner. The nut thread was totally stripped out. I called Grove and they sent a new set of bolts and the NAS679A6 nuts. I replaced both sides (nuts and bolts) and inspect the gear tower regularly--every few flights. I will definitely replace the nuts soon with the NAS1804-6, as suggested by Steve. Cheap insurance! I'm posting this to possibly prevent someone from wrecking their airplane. I almost did not post this account due to the unkind comments which may follow--take this post for what it's worth to you and keep the cheap shots to yourself....
