rjcthree
Is it possible that the 8 degree or so panel angle makes it more difficult to swing a VCC? In my case it's a PAI-700 in the panel, away from big power, no difference engine running, non running, a smidge (a twitch, 2 deg?) when transmitting. I can compensate N-S, but E-W I'm way out - 15 degrees or so. It's a tip up, so no steel. Brass screws.
Full disclosure, I might have over-adjusted the compensation elements at some point - could I have permanently damaged it?
Thanks, Rick
Thanks, Rick
