Danny Holder
I'm New Here
I am needing to hook up my wing tanks. I have a capacitor setup. What converter would you recommend? Thanks Danny Holder
I am using glass advance panel with an Engine Monitoring Controller. Yes, no float. Using capacitance setup. ThanksMore detailed info needed. What/who’s fuel gauge or EIS are you using? You mean not a float but capacitance setup? Me, no converter , what is it converting
The Dynon converters work fine with my Van's capacitance system.I used Dynon's capacitance to voltage converter.
Capacitance to Voltage Converter for Vans Capacitive Plates
Purchase builder support items or components to complete your SkyView system. For Experimental Aircraft Only.shop.dynon.com
...I believe they may be under a different name now, you'll have to ask someone else. They do require power, ground and signal wires, though. +5V IIRC.
Exactly how bad are the Dynon converters? Thats what I bought to integrate in my G3X system based on the recommendation of my Avionics guy. I know they work, but I haven't calibrated my fuel tanks yet to see how accurate they may or may not be.Here's a vote against the Dynon converters. I couldn't get them to work well. They worked, just didn't have enough resolution mid-range to show correct fuel levels as they only used a small portion of the 0-5V range.
I replaced them with the Princeton 2-point converters, and those have worked beautifully for a decade now. I believe they may be under a different name now, you'll have to ask someone else. They do require power, ground and signal wires, though. +5V IIRC.
