Firewall Insulation Retrofit
Mikeyb
I didn’t know about DanH’s work on firewall insulation when I built my plane.
https://vansairforce.net/community/showthread.php?t=47587&highlight=firewall+insulation&page=8
80% of my firewall was bare and I decided to install the .002” stainless foil and 1/8” ceramic as best I could. The blanket weighs 3 pounds.
As an aside, my intention was to measure the change in noise level and cockpit temperature before and after. I measured the sound level with a handheld sound level meter and the temperature of the rudder pedals with an IR thermometer.
At idle, canopy closed the sound level decreased from 86 dBA to 83.
Interestingly, At full power it stayed at 98 to 100 dBA with or without insulation.
The temperature test got muddled by the difference in solar load. It was overcast when I did the before test and sunny after. It lowered the temperature of the pedals by 10 degrees or more. Qualitatively it was the first time I was ever comfortable taxiing back after landing with the canopy shut and the vent closed.
I wonder if the full-power sound level in the cockpit has more to do with the voids above the forward belly skins. I would think on a typical Lycoming powered RV-8, those voids being just outboard of the air ramp would carry the exhaust note like a natural noise amplifier. I put some automotive sound dampening mat in mine for this reason, I also sealed this area to try and prevent water intrusion from degrading the mat.
Also, I was thinking about a firewall blanket for better fire protection. I hadn't even thought about it as a way to lessen cockpit noise.
I'm not surprised, although I've never personally measured the sound reduction.
I have about two dozen beta kits out there now, some installed, some not. These kits incorporate an intumescent insulation mat rather than the familiar Fiberfrax 970 felt.
Either increases comfort at normal inflight temperatures. The intumescent does a little better at high temperatures, as it swells to about three times its original thickness when heated over 650F. It's also higher density, so it should do better at sound reduction, and for sure it doesn't pillow as much under the rivet heads.
Photo below is 0.002 foil over 0.060" intumescent, five minutes into test. There are three thermocouples. The red meter is displaying the temperature of the aluminum angle (774F) and the temperature of the radiant heat target (200F). The black meter is displaying hot side temperature, 1101C or 2015F.
The radiant heat target (flat black square below) is 6" from the back of the "firewall", and serves as a proxy for the rudder pedals, the soles of your feet, etc. 200F is hot, but it's below the ignition temperature of most everything down in the foot area, and if you are wearing shoes, you can maintain control of the airplane. For sure it's way better than the bare firewall, which pushes the heat target above 400F in about one minute.
Of course I hope you never get to experience any of the above, and the only value is comfort in ordinary operation. Although subjective, I have a test for that too ;)
....At idle, canopy closed the sound level decreased from 86 dBA to 83.
Don't feel surprised or alone here. Noise attenuation effects are almost always specific to a fairly narrow frequency band. Sounds like you found where your mod is tuned. Ultimately, you can't very well reduce the sound power levels in our aircraft. The construction makes them very good at passing pressure waves for your body tp absorb. You halved the sound power level at idle; a fairly substantial accomplishment. Too bad that's not where you spend all of your cockpit time.
Your aircraft is safer and you got a slight side benefit. Call it a win.
Dan I'd be interested to hear more about these kits.
I had some type of flammable foam from the previous builder, which I promptly removed. Would like something more than just the stainless.
Is your desire for something more than stainless in the firewall to reduce ambient operating temps in the lower "footwell" area (for lack of a better term), or are you seeking increased fire protection?
I just spent two weeks in an aircraft accident investigation training course for work that is taught by the NTSB, FAA and several Subject Matter Experts. The instructors all have 35-40+ years' experience conducting aircraft accident investigations and one in particular (from the NTSB) is also an RV8 builder. I spoke with them in depth about accidents involving single engine piston aircraft that had either an inflight or post-impact fire.
All of the instructors and SMEs agreed there has been no conclusive data to support the idea that a single piece of SS used for the firewall (single engine piston) is insufficient to protect the pilot from fires. (100LL burns at around 845F, AL melts around 1,250F, Steel around 2,000F and SS around 2,500F).
Our Metallurgist Instructor stated in all of the accidents he has consulted on over the past 40 years, the single sheet SS firewall was still intact after the fire. The AL/Composite cowling and fuselage areas were the weak link.
NTSB data supports - Inflight fires were contained to the engine side of the firewall by the protection of one SS sheet and if/when post impact fires got to the cabin side, it was typically due to the impact rupturing fuel tanks or fuel lines - causing the fuel to spray aft.
The training facility also has a lab with several aircraft involved in fatal and non-fatal accidents. A few of the aircraft had pre/post-impact fire damage. Everything we inspected supported the conclusion that adding extra material to the firewall in hopes of increasing fire protection, is NOT value added. As you would expect, the plastic canopy and the AL (or composite) fuselage are going to be susceptible to 100LL fueled fires nearing the 1,000F range. (remember the SS firewall is good up to 2,500F)
Conclusion from the training (specific to single engine, piston AC) - If a pilot wants to increase fire protection for the cabin occupants, make it easy to open up the cowling to do a well-developed pre-flight inspection and carry a fire extinguisher that is easily accessible.
Ken
If you take the time to look at the work Dan did on this it’s hard to argue that engine side insulation is not a good idea. Even if you just look at the graph in post#3 you will see that in an RV your feet could be at 400F in 30 seconds. The firewall might be fine but you not so much. A relatively inexpensive addition that gives you precious seconds in the event of a fire and improves creature comfort.
Another temperature tidbit. 10 minutes after shutdown I measured the temperature of the engine side of the firewall of 150F. The temperature of the firewall inside the cockpit 75F two degrees above the ambient air temp.
In reference to static temperature measurements, certainly you can gain insulation from transfer of heat making passengers more comfortable. However, in a dynamic scenario involving forward flight, you have to consider high velocity airflow. You also have to determine what scenario will have you in the situation you are trying to prepare for. IF there was enough data to support this for design consideration, why wouldn't all of the airframe manufacturers (including Vans) incorporate the simple change? In the end, if it makes you feel more safe, it's your aircraft. :)
Another temperature tidbit. 10 minutes after shutdown I measured the temperature of the engine side of the firewall of 150F. The temperature of the firewall inside the cockpit 75F.
What about the bottom fuselage aluminum skin just aft of the firewall which would be exposed to a flame plume coming out of the cowl outlet (if there was an in-flight fire)?
Also, how do the aluminum rivets fare on the firewall which hold the angle stiffeners? Wouldn't those melt fairly quickly leaving a bunch of #40 holes in the firewall? I wouldn't expect those #40 holes to become mini-blowtorches, but they would let noxious smoke into the cockpit, no?
And, Ken, since when does avgas burn at 845F? I think you're missing a (1) in front to make it 1845F.
To your point, in the NTSB training we investigated an actual inflight fire caused by a broken v-clamp on a turbo charger exhaust tube that was mounted near the lower left section of the firewall. In this scenario the turbo exhaust temps are much higher than just burning avgas. (Turbo exhaust is approximately 1,000F hotter....1,875F) The searing heat did NOT penetrate the SS firewall. It did create a hole through the left side of the AL cowling about the size of a silver dollar. The heat was then exposed to the cooler slipstream and cooled enough to create soot and smoke down the side of the fuselage.
Unfortunately for the pilot, he lost the turbo a few minutes after takeoff and was over a congested city. He couldn't stretch the aircraft back to the runway and landed on a city street - finally striking a light pole. The light pole ruptured the left wing leading edge (Fuel Tank) and this sprayed fuel all over the canopy and fuselage. The wreckage was in the lab and we were able to inspect everything just as the NTSB did. (Fuselage had melted due to the post impact fire and the firewall was completely intact.) Again, this is heat generated by a turbo charger exhaust, which is well above 100LL auto-ignition burn temperature. (As a side note: The NTSB uses 845F as their number for 100LL ignition temperature during accident investigations to analyze physical metallurgy affects.)
Also, I did specifically discuss Van's Aircraft firewall design when speaking to the SME's about inflight fire containment. The instructors all acknowledged the AL angle and AL rivets would melt soon after exposure to 900+F. However, (their words) "The AL angle/rivets are not your real concern. Neither is the possibility of the small amount of potentially noxious smoke." "You have much bigger concerns... you have a fire that can spread and very possibly cause you to lose your engine." "Open your canopy or puncture a hole in it to let out any smoke and then focus on landing...hopefully without rupturing a fuel tank."
Remember the theory of a propane blow torch (2,000+F) aimed at a static firewall is NOT truly a representation of what NTSB accident investigation data has revealed.
For single engine, normally aspirated, piston engines, the NTSB data shows average fire temps below 1,500F. The NTSB determined this based on knowing the metallurgical make up of each part and documenting the type of damage sustained during the fire.
As the NTSB instructors explained to our class, science applied to the collected data tells the story.
A seamless sheet of 26 ga stainless steel is absolutely fireproof. The SS panel merely emits a lot of radiant heat on the cabin side. Care to define "protect"?
That aside, have you actually heated a two piece SS test panel, assembled with aluminum or monel rivets?
Dan,
As you are already aware, (as it pertains to a fire) the firewall (no matter what it is made of) is providing a fire barrier between the fwd and aft side. Not for a finite amount of time, as the high temps will eventually compromise the surrounding structure. The firewall merely helps to buy time for the pilot to get the aircraft on the ground as soon as possible.
That being said, your analysis is based on aiming a 2,000F torch directly at a simulated static firewall and taking radiant heat measurements. A basic understanding of Engineering properties could easily predict the findings.
What I am trying to pass along to you and the others is the information provided to me by several SME Engineers who each have 35-40 years of actual accident investigation experience. This particular group of instructors has investigated everything from single piston fixed wing to the Space Shuttle Columbia accident.
REAL WORLD accident investigation data does NOT show single piece SS firewalls as a design deficiency being causal or contributing to fire related crashes. If the data showed differently, don't you think Van's would modify their design accordingly.
If you are advocating for radiant heat protection on the cabin side because you believe the occupants will be subjected to dangerously high temps during descent for landing or after a post impact fire, then good on you. There's just no recorded accident data to support the need.
You don't have to agree with me. Please feel free to attend the NTSB training and discuss it further with them.
Cheers!
A bare, single piece stainless firewall is relatively safe. If you'll give me a dollar for every time I've sung that tune over the past 18 years here on VAF, I can probably fly to OSH free next year.
Anyway, firewall performance is never causal. Firewalls don't start the fires.
Oh, there's plenty of it, but again, it won't be listed as causal. Here's an example. Read the attached. This gentleman was a 1500 AGL over cut fields. Why were flames entering the lower part of the cockpit by the rudder pedals? Did anyone consider the question?
Dan,
Cheers!
Can I ask what point you’re trying to make Ken?
Is the firewall a design issue? No.
Can good quality firewall insulation improve outcomes in the event of an engine fire? I think the answer has to be a qualified yes. Qualified as in there’s not enough data comparing engine fires in single engine aircraft with insulated firewalls with those that are not insulated. However, a firewall covered in a good quality insulation will at worst be a waste of time, and at best be a life saver. I hope never to find out.
It reminds me very much of the argument around the wearing of parachutes. How many RVs have come apart in flight? How many pilots have successfully bailed out of an RV? Yet many of us still ware them, and for some are a legal requirement. The chances are the wearing of a parachute is utterly pointless, yet can only improve the chances of a successful outcome. Much like the argument around firewall insulation.
One of my biggest bug bares with light aircraft is the presence of fuel in the cockpit. That is why I will carry a fire extinguisher, and won’t ware nylon clothing. My decisions, I hope, will prove to be utterly pointless and unnecessary. But it won’t stop me making them.
... If a pilot wants to increase fire protection for the cabin occupants, make it easy to open up the cowling to do a well-developed pre-flight inspection ..
Reminds me of a podcast I just heard - ilafft:
https://overcast.fm/+nLF90EcEQ
https://podcasts.apple.com/us/podcast/68-hidden-hazard/id1544875746?i=1000628710321
https://podcasters.spotify.com/pod/show/ilafft/episodes/68--Hidden-Hazard-e29jije
(sorry about all the links - there does not seem to be a link to this podcast on the Flying.com website)
Jonnyb, my original comment was to Moe's statement which gave me the impression he might be concerned with the ability of "just the stainless" to protect the cabin from an inflight fire. If that was an incorrect interpretation, that's on me.
My point is this:
If anyone is concerned with the ability of the current firewall design to perform its intended design intent, my posts were just to share what the NTSB and FAA, teaching Aircraft Accident Investigation, had to say on the topic.
This is experimental aviation and everyone is entitled to customize their aircraft as they see fit to contend with any perceived safety issue. If adding additional insulation or modifying your firewall makes you feel safer, great! It's your decision.
Dan - Your clip is merely a snippet from a pilot's post-accident interview. There is a lot of missing information that would be taken into consideration during the investigation to determine if the lower firewall did not sufficiently protect the cabin area. You have to consider ALL evidence gathered in an investigation. Beware of "Confirmation Bias".
My point is this:
Which current firewall design would that be?
As long as we're talking about seamless stainless or equal, I am of the same opinion. But we're not.
Actually, from his NTSB Form 6120.1.
Yes indeed. That's the point. Where is the information? Did anyone at the NTSB bother to ask why a pilot was burned despite optimum conditions...a cruise altitude of 1500 AGL, with a mowed hay field on the nose, and a flight duration of not much more than one minute after first evidence of malfunction?
I previously asked you to define "protect". Here we had open flame in the cockpit in less than 30 seconds, while the certified standard (23.1191) is:
(g) Firewall materials and fittings must resist flame penetration for at least 15 minutes.
BTW, I interviewed the pilot. Ex-Marine. His written self-description of "minor burns on my lower legs" may have been overly modest.
Dan - It's apparent you disagree with the NTSB and potentially their processes. I am not interested in further entertaining your arguments.
Please feel free to take the training so you can communicate your thoughts directly with them.
You are the one arguing Ken. Arguing against a simple modification that has little downside and several benefits.
Further? Ken, factually, you've brought nothing to the discussion beyond a secondhand account of instructor opinion regarding a narrowly defined case, specifically seamless firewalls...an opinion with which I agree.
We disagree when you apply that opinion to the whole fleet. It's simply not true.
Look, folks want everyday inflight comfort. The most effective approach is to insulate the hot side. Make good choices in materials and technique, and you get extended fire protection in the bargain. Hopefully you'll never use it, but hey, what's not to like?
Dan's longstanding and patiently researched endorsement of insulation on the forward side of our firewalls may or may not ever gain an unfortunate victim of an in-flight fire very much margin, but I suspect his simultaneous campaign against insulating the aft side of the firewall has or will save lives someday.
You can bet the foam sound insulation promptly came off the cockpit side of my -6A after reading his original post years ago, and my -10 was built with Fib-refrax blanket and SS foil on the engine side.
Thank you, Dan.
Root cause, direct contributor, secondary contributor,...
and other "subjectability". Some interesting and flawed arguments.
So, if a firewall doesn't breach during an in-flight fire but the local temps _____ly prevent a pilot from effectively actuating rudder pedals. As a(n) _____ result, the aircraft ground loops upon landing and ______ly causes major injury or loss of life.
Did the product: meet spec, meet expectations, meet design intent?
We get to build what we want in this non-cert world. Sure, risk parameters have to be evaluated and the high consequence, low probability corner of the FMEA (a far too linear process, IMO) typically makes for the hardest decisions.
Having said all that, judging someone's conservative approach regarding safety is a bit presumptuous in my opinion (which counts for nothing here.)
Be smart. Ask questions. Build safe, (drink beer, and pet dogs)
Firewall
I trust Dan. Fiberfrax and titanium on my firewall. Anybside benefit appreciated for minimal weight gai
A little knowledge is...
There are a lot of terms and concepts being thrown about here, much of it incorrectly and inaccurately:
Engine exhaust gas temperatures are much lower than avgas flame temperatures because some of the heat is consumed through gas expansion and resultant piston work before the exhaust exits the engine.
Turbo exhaust is not 1000F hotter than "just burning avgas". Avgas burns at over 3800F! It is typically a bit hotter than non-turbo exhaust temperatures because the exhaust gases upstream of the turbo have not fully expanded to atmospheric pressure and therefore have not cooled as much as NA engine exhaust. However, in the case of an exhaust leak upstream of the turbocharger, the gases continue to expand through the leak and cool down towards the temperature of NA exhaust when they exit the pipe- but they're still hot enough to burn aluminum!
Auto-ignition temperature and ignition temperature are completely unrelated to "burn temperature". Auto-ignition temperature is the temperature at which something will ignite without an external ignition source, and the Conoco-Phillips MSDS for 100LL quotes that as 824F - similar to the 845F temp you quoted above. This has nothing to do with "burn temperature" which as stated above is much hotter - over 3800F flame temperature.
I'm not sure what the NTSB instructors point was but considering most piston aircraft POH's call for shutting off the fuel valve at the first sign of a FWF fire, an engine out is a given. Ideally we do our best to prevent the fire in the first place by following accepted practices for FWF installation and by performing frequent inspections. Thermal protection is a last resort but following Dan's recommendations significant additional protection can be added to our planes with little weight and cost penalty.
Well this particular NTSB instructor is entitled to his opinion, but I would want use something other than an "average" for protecting myself from something as extreme as a FWF fire. If faced with a FWF fire, I would like to not be overly distracted by my feet burning up while likely trying to make a dead-stick emergency landing somewhere. In the case of my RV-8, I followed Dan's advice and insulated the forward side of of my firewall with stainless foil encapsulated fiberfrax insulation. I also replaced the aluminum cooling air outlet ramp with stainless steel and applied encapsulated fiberfrax on the inside of that as well as replaced the stock aluminum cabin heat valve with a stainless one. Eventually other parts of the fuselage may burn through given enough intensity and time, but we try to do the best we can with what we have.
Skylor
I am one of Dan’s beta test sites for firewall insulation kit. I elected to go with the heavier SS foil (0.005) and thicker tumescent insulation (0.1). The heavier foil allowed me to score it which gave it a quilted look and almost eliminated the reflected wave look. That step was not part of the install instructions but was my touch and I hope it makes Dan a smidge proud of the outcome. The quilting also hides little dents that occur during the install.
I am delaying attaching the top skin and the flange for the Skybolts until I run the wires for the engine which will be hung in the very new future.
I also am installing 2 thermocouplers for early fire detection.
Pics are bare foil, smooth foil, foil with attachments clecoed on, and quilted foil, and quilted with attachments riveted or bolted on.
I’m looking forward to noise reduction and improved cabin comfort and pray I will never need the added level of safety.
But, as I recall, it is the standard the FAA uses for firewall testing. Which Is what I believe Dan was trying achieve.
I think it looks great. Probably work fine with the 0.002" stainless also. Dull plastic pizza cutter and a straightedge, roll in the crease.
Yes Mike, I have tried to stick with the FAA standard as much as practical in a non-laboratory environment. Note the standard is changing, as the specified oil burners are apparently no longer in production. A propane flame can generate the required 2000F temperature at the test surface, but doesn't deliver quite as much energy; a lot of it radiates away through the clear flame envelope. The FAA has been working on a new standard for propane test rigs. Probably complete by now; I have not checked.
Point is, a propane test rig with a simple 25 sq in hot spot at 2000F is not as severe as the old standard with the specified oil burner.
The environment inside cockpit may not be human friendly with fumes, smoke, visibility non existant. You may have a few minutes to get on ground and may not be able to see... Dire circumstances. You can opt for fire hood so you can breath.
The fiberglass engine cowl will allow the wind screen to be impinge by heat and oil and flames. Fiberglass burns. Jets have titanium dog house all around the APU.
Smoke in cockpit from fire in airliners, large jets, in past accidents incapacitated the flight crew either physically or inability to see.
Standard full face mask/O2 is now supplemented with a tent. Past accidents showed crew could not see the flight instruments. They now have tents that go over instrument oanel and crew to allow pilots to be isolated from smoke.
SS firewall buys time. Depending on fire intensity may help to get you on ground. In flight fire may not be survivable regardless of insulated firewall or not.
I always think of the RV8 accident in Oregon, may be 20 yrs ago. The engine exploded. The piloted bailed out... without a parachute. It was that bad.
Not kidding fly with parachute. Plane is on fire get out.
Another option, fire suppression system, halon. Jets all have engine fire suppression. Big red fire handles are pulled, cuts off fuel lines, hydraulics and pneumatic SOV's (shut off valves). Then you turn them and blow the bottle of fire retardant. Then if fire is still going, turn handles to blow 2nd bottle.
So smoke hood, parachute, fire suppression.
The fiberglass engine cowl will allow the wind screen to be impinge by heat and oil and flames. Fiberglass burns. Jets have titanium dog house all around the APU. Want more fire protection? Titanium cowl and firewall.
Some airlines supplements standard full face mask/O2 pilots put on. Past accidents showed crew could not see the flight instruments. They now have tents that go over instrument panel and crew to allow pilots to be isolated from smoke and see.
Another option, fire suppression system, Halon 1301. Jets all have engine fire detection & suppression. Big red fire handle is pulled, cuts off fuel lines, hydraulics and pneumatic SOV's (shut off valves). Then you turn fire handle and blow the bottle of fire retardant. Then if fire is still going, turn handle to blow 2nd bottle.
Jets also have fire detection systems not only for engines but cargo and passenger compartments. Cargo planes have systems that punctures the cargo containers and fills them fire suppressant.
RV pilots have none of this. Back to parachute. A parachute would have saved that RV8 pilot.
Ken
adiabatic flame temperature of gasoline is over 2,000c in air. Interestingly not that different than wood or anthracite coal, and slightly higher than propane or natural gas, all of which have been used to smelt steel. Burning jet A melted plenty of steel in Tower 1 and 2.
Has anyone actually successfully bailed out of an RV-8?
Do you think it can't be done? There are threads galore on the topic. The tragic RV8 bailout (on fire & no parachute) I mention above would have, I assume, been successful, if he had a chute. I recall postmortem on final report, pilot had signs of being burned and smoke inhalation in lungs. I am sure w/ a chute he would have got out sooner. I'm also sure firewall insulation would not have helped.
So yes I 100% believe it is possible and a life saver to bailout of RV's with a chute. Has anyone done it out of an RV? Don't know. I offer more would if they had a sport parachute on abd might otherwise be alive. 1000's of pilots have used emergency chutes to save their life. This is well established "thing" for over 100 years.
Legally (and smart) you and your passenger are REQUIRED by FAR's to wear a chute IF DOING AEROBATICS. Solo? No chute REQUIRED for aerobatics. If doing training for a rating (CFI required spin training) chutes not required. I think all RV pilots doing aerobatics should have an emergency chute even solo, take a seminar and training on how to use it, have a plan to get out (canopy release).
Chute makers who offer Pilot Emergency Parachutes: National, Strong, Softie (Para-Phernalia), PARI Precision Aerodynamics, MarS, etc. have LONG lists of saves... So yes it is a safety device that works regardless of make model of plane.
A bizarre RV accident I recall, reading NTSB accident report, plane (RV) crashed and pilot (no chute) was a mile away. Went thru canopy. Seat belt NOT on/secure and did impromptu aerobatics? I don't recall if there was finding od why. Point yes you can exit RV's in flight. Yes a chute will save your life.
The question is can you successfully bailout of any RV. Not with standing the obvious have a chute, I say yes with exceptions.
RV3 and RV4 the canopy is opened and rips off side piano hinge. I know the can come off as several canopies departed in flight inadvertently over the decades. Most of the time pilot landed safely. Know of no intentional bailouts.
RV6, RV7, and RV9 tip up has canopy ejection handle (or can have one installed). The Slider canopy at speed, will not open very far. You need to add ability to disconnect fwd slider attachments x2 and open overhead latch, 3 step process.
RV14 I assume has ejection tip up canopy design as before. There is no RV14 slider.
I just flew an RV12 yesterday. First flight of aircraft. I'm doing the builder/owners training and flight test. No way to bailout, jettison canopy in stock form. With mods yes I assume. RV12 is Non aerobatic plane. See below, we *me and owner* had smoke, burning 🔥 smell during 1st flight.
RV10 I don't believe you can bailout unless you put in a way to jettison doors. Non aerobatic plane.
C 152 "Aerobat" has jettisonable doors. Handle pulls cable and pulls 2 pins out of the 2 fwd hinges.
How many military planes don't have ejection seats? Some. Still ejection or jumping and hitting the silk is time honored method of saving pilots bacon that works. There are 1000's of military and civilian pilots who lives were saved by a parachute.
If you are worried about a massive fire 🔥 I would take a parachute over firewall insulation!!!!!!
BTW On 0.6 hr first flight of the RV12 I flew yesterday, there was a hint of a burning smell for a moment about 20 min into planned 30 min flight. The exhaust toasted a half dollar sized area in cowl. Builder knew this area of cowl got hot from previous taxi and ground runs. So he wrapped exhaust. It did not get better in flight. Discoloration of paint turned black 😳. Needless to say he is doing modification repairing. That wiff of smoke although momentary shows SMOKE GETS INTO COCKPIT, EVEN A LITTLE SMOKE, MUCH LESS RAGING GAS OIL FIBERGLASS FIRE.
In event of an engine fire, it is a few feet from your feet and face. There are leaks in canopy and firewall. That propeller and airflow is blowing at hurricane force that fire and smoke at YOU. My ideawould be GET THE FUDGE OUT, E.G., PARACHUTE.
Yes I owned a chute, used it often, but mostly aerobatics. I sold the chute with my RV. I need a new light slim type (Softie mini). I don't wear a chute always especially long XC trips. But a Softie Mini is 14lbs and could be worn always. The new slim and wedged backpack emergency chutes are comfortable, but you have another harness plus seat belts. You get use to it. I always put chute on before getting in and get out with it on. Always store chute in hard case (like a big suitcase) in your heated cooled controlled home.
I need a new chute. The Para-Phernalia emergency backpack shell I had is *no longer made*. It had a new surplus w/ 28' military high opening speed (jet) canopy. More bulk and weight. Bad part chutes are several grand now. A Mini is +$3K, most in the $2K to $2.5k range. Airshow specials is good time to buy,
I am sure if more sport experimental pilots wore and trained in how to use emergency chutes lives would be saved, more lives than firewall insulation. 😀
PSS Bailout not only for fire, if you have a Mid-Air, Structural Failure, Flight Control System "jam" or disconnect, loss of engine power (no fuel) at **altitude** BAILOUT might be a good option.
** How low can you get out? About 1000 feet **if** aircraft (and you) have a vector that is horizontal to ground with forward speed. If you get out at 150 kts going straight towards the ground you will need much more altitude. It is just math and physics. Chutes have strict demonstrated open times per TSO and FAR's... So you could in theory step out of your RV in the pattern at 1000 ft AGL, pull rip cord, swing one or two times under canopy, before back on mother earth in time to see your pride and joy auger in (or fly off on autopilot and land itself in a field 300 miles away). Laugh look this up https://en.wikipedia.org/wiki/Cornfield_Bomber
As mentioned above, in 1999 there was an RV-8 that caught fire in flight. The pilot did get out, but unfortunately he was not wearing a chute. The NTSB said that the fire may have been so intense in the cockpit to be intolerable (the WWI scenario before chutes were widely used).
Here is the NTSB Final Report:
Thanks for posting..... Two interesting things....
They still have not released docket with all the supporting investigation information, pictures and diagrams..... Wonder why? This data might be useful in a firewall insulation debate. How about some suggestions from NTSB. How to make this more survivable? It seems they do imply parachute would have been useful.
Ref: Page 9 of 12 SEA99FA113
SURVIVAL ASPECTS
Although the pilot had acquired and utilized a parachute during the first approximately 25
hours of aircraft operation, he was not utilizing the parachute at the time of the accident.
The aircraft's canopy is airfoil shaped and during flight conditions would tend to create an
aerodynamic low pressure condition near the top of the canopy (just aft of the seam between
the windscreen and canopy).
So what are they implying with the low pressure and canopy?
Does the RV-8 Canopy not slide back in flight or does? Apparently he got out. Point of this statement I found elsewhere, is post-mortem pilot's eyebrows and forward hairline was burned. So opened canopy allowed heat and fumes into cockpit (faster and more intensely). Takeaway with slider don't open in a fire situation, unless you want to get out with a parachute. Same with jettison-able tip up canopy. If canopy remained closed, made a forced landing,, he may have survived? May be but it would have been difficult, due to obscured view out windscreen. It would have been an awful situation.
They point out pilot had and used a parachute in early flight test. Are they saying a chute would have saved the pilot? Just being ironic? Not the best report I have read. However I do think a chute would have saved the pilot.
Funny how someone always raises the specter of "massive fire".
This isn't a movie script. There are three flammable liquids forward of the firewall...fuel, oil and brake fluid. Fuel is a finite quantity, with a pilot controlled shutoff. Oil is a real problem, given a there is no shutoff and quantity is well over a gallon, but flow usually stops if the prop is stopped. Brake fluid is a non-issue...at least until the plastic fitting on the back of a firewall reservoir has an opportunity to melt.
The primary purpose of firewall insulation is ordinary comfort. The past problem was builders obtaining that comfort by placing flammable insulation materials in the inside of the firewall. Some of those materials, when in contact with a hot firewall, can result in a roaring fire inside the cockpit within seconds of ignition firewall forward. The best case is a lot of smoke.
Insulating the engine side of the firewall is more effective for comfort control, and is beneficial in the event of fire, rather than a liability. The benefit is time.
With 60 extra seconds, pilot can (a) realize there may be a fire, (b) confirm there is a fire, (c) decide to do a shutdown, (d) get it shut down.. He can close a fuel valve, look for a place to land, and maybe even stop the prop is oil is evident on the windshield. Put another way, given time, the fire doesn't get massive.
This is my primary reason to wear a parachute every time I fly my airplane. I won't probably find a suitable landing field in time before the fire gets out of control. The chute is comfortable when you are sitting inside the airplane.
By definition, Adiabatic flame temperature assumes "No heat loss in the process". That's not the case with inflight fires. The NTSB and FAA determine the temperature reached based on which metals have melted near the source and which remain. Side note: The NTSB consults with several Metalurgical and Material PE licensed Engineers for both post-crash metal fracture analysis and to establish processes and protocols concerning max temps reached. They have a wealth of knowledge at their disposal.
To your other point, unfortunately I am quite familiar with the events that took place during 9/11. I worked for UAL at the time as 1 of 2 Structures Engineers with their 757/767 Fleet Engineering Team. Our 767 was the second one to hit the twin towers and our 757 went down in Shanksville, PA. :(
