Anyone have the 4 engine motor mount numbers handy? My lowers are starting to sag
R Robb Well Known Member Feb 16, 2021 #1 Anyone have the 4 engine motor mount numbers handy? My lowers are starting to sag
swaneymj Active Member Feb 17, 2021 #2 Lord J-7764-31 are the aerobatic engine mounts. I purchased mine from Herber. The others are J-9613-12. I'd recommend the aerobatic ones, although the cost is higher.
F1Boss Well Known Member Feb 17, 2021 #3 Maule 540 numbers The parts used in the Maule 540 are good parts - could be one of those that Mark mentioned? If I could recall the right number, I would tell you...
J jmwigen Member Mar 31, 2021 #4 Lord mounts Just replaced mine in Rocket s/n 097 Lord P/N J-7764-20 Same as Lord mounts for the Extra aircraft. Cheers.
