I have been troubleshooting occasional and erratic low oil pressure and to a lesser extent low fuel pressure readings on my GRT EIS for sometime now. I finally found the problem so I wanted to share with others who might be experiencing the same issue. The fix: I moved the ground wire for the EIS FROM a stud on the engine which was shared with and on top of the ground wire for the Emag electronic ignition TO the forest of tabs ground plate that I had riveted to the firewall. This change also shortened the ground wire about 3 feet. Since this change my OP and FP have been rock solid. The manual for the EIS said to connect the EIS ground wire direct to the engine so that's what I did but little did I realize the spikes in the ground current the electronic ignition was causing.
Hope this info will save others time in their search for causes in low OP readings.
