thehagg501
Member
Patron
I pulled out my top wing skins and one of W-00002 has this spot beneath the vinyl. I rubbed it off with some 800 grit. It seemed like it was just some dirt. There isn't an indentation in the spot after removing. Build on?
Looks like an inclusion in the aluminum, maybe something got on the rollers where it was formed into a sheet in the first place.
Never seen that before. I agree better to give Vans a call in the morning. If me, would ask for a replacement part.
I don't think it is a problem because it looks like it is on the surface only and it should not be sanded out by more than 10% of the thickness of the sheet (see AC43.13-1B).
If using 800 grit then ensure it is not silicon carbide "wet and dry" because the carbide grit can embed and cause corrosion on aluminum. Scotch brite (aluminum oxide) is a safer bet.
Being the top skin, I’d give Vans a call.
If it was the bottom, I’d deal with it by dressing it out, or patching it.
Thanks for the heads up on the grit, it's 3M 213Q. I should have been less invasive, think it would of wiped off with water actually.
