Hi Guys,
Wow I started this thread and haven?t been around in a while, it has grown significantly.
Here is where I am at, with a couple of pictures below?
1)I got the arm that points the other way
2)I used the vans VA-182-PC bracket instead of the standard one that comes with the standard carb FW FWD setup.
What I noticed so far:
- The metered hose supplied by SuperiorAir going from the Throttle Body(TB) to the FI spider will work, but runs close to the exhaust, I decided I will put some additional fire sleeving on it for the section close to the Exhaust, because I don?t know how good the protection of STD brown hose is.
- The supplied hose from the Fuel Pump to the TB inlet will not work, it just runs too close to the control cables for my liking, and might cause chaffing. I decided to have a hose made up, a little longer. I will have to figure out how to support it for the last run between the engine mount and the TB inlet.
I have not tried my airbox or cowl on yet, so I don?t know what the alignment would be. I did fit the heat insulator between the Sump and the TB, you can see it is a brownish colour, between 3 supplied gaskets.
This is my first engine install so if you see something odd, let me know!
Will keep you guys posted?If you figure out something I haven?t yet please post below.
Kind Regards
Rudi
