Desert Rat
Hey all- On the G3X setup page, you can select flaps absolute position or flaps relative position. My understanding is that If I select relative, I can then select set points and then if I bump the switch down they will go to the next setting and stop there without me having to hold the switch down. At least my reading and playing with settings today lead me to believe thats what's happening.
Is there a way to make that same thing happen when retracting the flaps? So far all I seem to be able to do is retract them by holding the switch up. i.e when I let go of the switch instead of continuing to the next set point they just stop wherever they happen to be.
I looked in the manual and info was pretty sparse on this topic.
