I know the WD-1002 brackets tend to give builders trouble but it seems like most people have to figure out how to get the top and bottom tabs pushed inwards far enough to be able to match drill them. For me it's the vertical tab that is not aligned well enough with the F-1040 upper fuse channel so the tab runs into the curved part of the channel.
The recommendation from Van's is to somehow push the tab upwards so that it fits where it needs to but I'm not really sure how to accomplish that with the skin and channel in place, and I'm skeptical that it can be moved as far as it needs to go. Has anyone else run into this problem with these brackets and if so how did you solve it?
My initial plan was to grind away everything below the line with the arrow in the picture below. The only problem with not getting the tab pushed upwards is that there isn't very much distance between the aft top hole and the edge of the steel tab.
