I've recently purchased a RV-8 with the VPX system and I keep running into a circuit that is shorting out. I've looked for shorts, swapped out boxes, and sent a autopilot control panel back to Dynon with no success. Working with a couple of guys that have built their own RV-8s and use the VPX system we think I may be down to swapping the wire / pin on the VPX system to see if the problem lies in that specific pin. If that doesn't work I may be down to sending the VPX back to get checked but I'm waiting to talk to those guys tomorrow.
My question is, has anyone ever run into this type of issue and had luck swapping out the wire/pin location in the VPX system. This is specifically a trim circuit but it's not shorting when the trim is being used. The timing of the short varies but it's never when the trim is being used.
Thanks in advance,
Skip
Thanks in advance,
Skip
