What makes an airplane with close to a thousand hours and almost four years of experience suddenly begin to experience vapor lock after a fuel stop? I have been flying the Val for all that time and never had a single problem, until about the last two months, where I have had three experiences with it during short-turnaround stops; Twice when I had fueled, and once when I just shut down for about five minutes to drop off a passenger. I have looked over all the fuel lines and systems - nothing has changed, so I am going to have to blame it on this unbelievably hot and miserable summer we are having! Twice this happened after short local flights for fuel in the Houston area, and once over near Phoenix, where they appeared to be beta-testing the new climate from heck?.
Now anyone who knows me knows that I am pretty much a believer in bone-stock fuel systems. I have read too many accident reports where experimental aircraft have lost power due to fuel starvation to want to play around with that part of the equation. (Before I get a flurry of responses from those who have upgraded their systems from van?s design, let me say that I have nothing against carefully considered and well-thought-out modifications. I have a little heartburn with folks changing stuff just to be different and because they saw someone else do something similar?.that?s all!). I have a pure Van?s system with a carburetor, and in three summers, have never experienced this. Ten minutes of cooling down with the oil door open seems to relieve the problem, and once fuel is flowing - no problem at all. (Actually, since the problem manifests itself with the boost pump hammering away at high frequency, I believe the problem is with it sucking fuel out of the tanks, so I am not convinced the problem is under the cowl?.). There have been no in-flight issues, because once the fuel gets flowing, the problem disappears - and believe me, I do some serious ground power checks before take-off after experiencing this!
In all seriousness, and hoping to elicit ideas other than ?put fuel pumps in the tanks like cars do!?, I?m curious if anyone else has seen an increase in vapor lock incidents this year. Is it higher temperatures, and we have always been operating just a couple of degrees below the ?critical temp?? Is there something knew they?ve been doing to AvGas this summer? Could boost pump age have something to do with it? Am I just getting my turn-around times so short that the problem is just appearing? Any other ?out of the box? ideas?
And has anyone else noted a problem this summer, or is it just me?.?
Paul
Paul
