I'm hoping to get an answer to this more from an aeronautical engineer's perspective.
In researching this for awhile I have not found the answer.
When looking at manuevering speed, one of the definitions is the speed at which a maximum deflection of one of the control surfaces is still safe. But reading further, it seems it is to avoid a maximum deflection from exceeding the g tolerance of a particular aircraft.
Reading further, most are speaking about maximum Elevator deflection. For example, at X speed, you pull all the way back, and have now exceeded the G forces to which the airplane is rated/designed.
I'm wondering with respect to full aileron deflection if this is the case, as you are rolling the aircraft, but it is certainly not pulling much if any G's.
Will full deflection of the ailerons at speeds above Va potentially damage the ailerons, or is this not so much the case?
I notice many pilots roll their aircraft a margin above Va.
