Ed_Wischmeyer
Well, I'm glad the plane was fully insured...
The additional items beyond the repair estimate (below) that we know about and are watching are paint touch-up -- essentially every upper surface on the plane, plus the fin and rudder; and any propeller work beyond the funky leading edge corrosion, far beyond normal abrasion. Paint matching and touch-up should be less than $10K; and the propeller will be zero if it's okay, $10K to replace. (Anybody got a great deal on a new Hartzell constant speed for an O-320?)
So... Estimate from the shop is $13K; and $2.3K to Garmin for fixed price service to clean out any soot that might have crept in to the cooling air channels in the GTN and the transponder. Probably a few other little things.
It looks like all this will come in maybe under $25K, but there might be $10K more if the prop doesn't pass muster.
This level of repair is to get rid of all smoke and soot-induced corrosion, but it is not to put the plane in concours condition. Smokey has a thousand hours on her, so she's past the looking-like-brand-new stage.
The plane is airworthy now (after they check the prop corrosion) because the corrosion has only just started and it will take a while before the corrosion grows to dangerous levels. The shop will work on the plane but no longer at AOG priority. My guess is that completing everything may take a few months, but I'll be able to fly it when they're not working on it.
Looking back at comments on the previous post, there were a number of enthusiastic comments unhindered by fact....
UPDATE: The leading edge of the prop dressed out satisfactorily, so the prop does not need to go to the prop shop nor be replaced. One less hassle to deal with!!
