Bill.Peyton
Installed the pitch servo using the Tru Trak supplied bracket and hardware. I am concerned that the torque multipier arm could get hung up on the top rear bolt head. I ended up shimming the oposite end with an additional washer to kick the back end of the arm further away from the bolt head. I believe the correct solution is to use a countersunk screw and let the threads protrude through to the servo housing and safe tie the screw on that end.
I know this probably belongs in the A/P section, but it is RV-10 specific.
Anyone else see this as an issue?
