No strobes firing even after engine start. 13.5v charge from alternator.
Checked continuity of circuit from CB thru switch to controller. Have 12V at controller from ships battery but no fire. Vic Syracuse verified controller working during annual by "hot wiring" power to the control unit. I don't know exactly how he went about doing that but I have seen photos and videos of a "power unit" hooked up to the controller and "jumped" as per the Whelen install guide.
2 questions. Should I use the jumper port (the input just to the right of the main power input port) to test the system further and what power source can I use to supply a full 14+ volts to the unit. The manual says it might take 14v to fire the unit on the ground.
