Trying to help my hangar neighbor diagnose some odd issues in his plane.
I'm going there tomorrow with my voltmeter.
he has a split bus bar with one side showing 12.3 volts and the other showing 14.1 while the engine is running.
He shows a voltage drop of .5 volts on the 12.3 side when the push to talk switch is depressed.
also has some alternator whine when transmitting on the #1 radio.
when receiving both radios are quiet.
anyone have any thoughts??
I'm going to check for proper grounds, & the headset jacks for isolation washers.
Going to check the alternator for ripple voltage/bad diode.
Will check the voltage regulator too. Seems to me both electrical busses should be regulated the same. How they differ by 1.8 volts is odd.
