Yes and yes. At least, my DAR wanted them done before he showed up. You don't need a shop necessarily, but you do need someone with the right equipment.
My DAR just checked that my ELT was outputting, but I wasn't flying anywhere where I needed the transponder. However I was able to check it on the ground prior to first flight. I waited until out of phase 1 to have my pitot static certified by a repair shop. As far as I know that's only required before a?ny IFR flight.
I was referring to the pitot static certThe 24 month transponder rule IS required for VFR flight. (ref ? 91.413)
Another data point. The Reno FSDO requires pitot static check prior to their inspection. Dan from Reno
