rv8pilotpaul
Active Member
Anyone know if the F-1294A and F-1294B Tailcone Fairings are part of the Empennage kit?
Jim,
I asked Scott about that. He said he thought you could still get it on with the tail on but it would be easier if you took it off (yuck!) From what I can tell in the plans...it should be possible right? After all, it is an inspection portal anyway is it not?
Pete
wings/fuse/tail
Mine is currently on with all the washers set and so is the Vertical Stab and rudder. Are you saying that when the finish kit comes it is possible to fit and install the tailcone fairing without removing the stabilator and the rudder?
