I can clearly see the scratches on the bosses from the press-fitting of the bearings.
greg
Any of those scratches in the immediate area of where the part broke?
I've never installed a rocker shaft bushing. It isn't something generally done in the field. Fresh cylinder assemblies come with the bushings already installed; we just check the shaft fits.
However, the numbers are in the books. My Lycoming manual says the bushing OD to boss ID press fit should be between 0.0022" and 0.0038" interference. The actual boss ID is 0.7380"-0.7388", so you would need bushing OD between 0.7410" and 0.7418". Not much room for error.
It's a pretty tight press fit for a hole less than 3/4". The manual says nothing about heating; just drive in the bushings using the specified drivers. So yeah, it would be easy to gall the bores, even with correct fits. Nobody can tell you what the interference fit may have been by looking at a photo of the galling.
I tend to discount the "bushing too big" theory. If it was so big that it cracked the boss during installation, it should have grown some beach marks between then and now (partial crack), or show contact damage at the faces of the break (fully broken). If it didn't crack at installation, the bushing oversize shouldn't make any difference. I think the additional hoop stress would act like bolt preload, reducing the fatigue effect of cyclical loading.
Given clean crystaline faces in the break, I think you're still looking at a one-shot overload. A galling gouge could serve as a "break here" stress concentration.
Obviously I like the subject, but again don't depend too much on me. I'm not a professional.
POSTSCRIPT: No point in leaving stones unturned. You can easily measure the bushing OD's. It may be difficult to get a good measurement of the boss ID's (given that they're broken into half-moons), but they were cut with a piloted reamer anyway. It's tough to get an undersize hole with a reamer.
Has anyone called Superior yet? It has been reported that they have honored some warranty work that dated before the new owners took over. Just a thought, it might be worth a call.
Rather than debating how many teeth the horse on the other side of the field has it is easier, but less fun, to just go over there and count them
I was thinking about how I wouldget comfortable with other jugs myself Bob. I figure that taking off the rocker covers for a viual would at least give a gross check. I am wondering if a field-type Dye-pen kit might be used on the other bosses to see a little more detail.
I'll admit that I haven't used one for decades, so may have forgotten the limitations.
Spoke with Bill at Superior this afternoon. He has been talking with Lou at Eagle Engines as well. He volunteered to send me a cylinder but it has no other parts with it (like valves, guides, etc.) and I already have an ECi on the way. Superior is not making cylinders again yet. We discussed a couple of the potential failure causes, and need more data to assess, but apparently this is the only one out there with this failure mode.
Doesn't sound like any fiscal help on the way at this point.
Oh, and the ECi excuse for the delay in sending the cylinder was "holidays, lots of people out of the office" which still isn't excuse enough for telling me one thing and doing another.
greg
He sounded bushed, but I told him to be sure to let it all ride on double-zero...and get this engine work paid for in a few spins!
More to follow from Greg.
Bob
I talked to an experienced mechanic yesterday afternoon and he was convinced that the bent push rod was almost certainly caused by a sticking exhaust valve.
What do you suppose is the significance of the power reduction in the onset of the failure?
Knowing now that a stuck exhaust valve is a possible candidate cause - what does that add to the discussion?
I have in mind that lead condensing and solidifying on the valve stem may be the mechanism for a sticking valve but this would require a massively fast reduction in temperature.
I found this interesting:
http://www.avweb.com/news/maint/182894-1.html
....Not neccessarily. We tend to think in terms of CHT, but actual component temps are different. There's a chart in Taylor's "Internal Combustion.." with temperature measurements at the mid point of an exhaust valve guide for a large air-cooled aircraft cylinder The range is about 425F to well over 600F. The valve itself is 1000F to 1200F at the face and stem temperature would be a gradient. Elemental lead has a melting point of 622F. Liquid to solid is a range of just a few degrees, and the neighborhood temps range all around the melt point.
Me too.
He had just started a slight power reduction from about 2500 RPM to about 2300 RPM for cruise, when the engine started running rough. That would not seem to be such a radical power reduction as to cause rapid cooling, as Mike was referring to.
Bob
The RPM and standard day pressure would suggest something over 80% power, maybe 85%. Leaning to peak was, mmmmm, very aggressive.
At 100 seconds into the flight (point 20) it's at WOT and full rich. EGT's are ballpark 1250-1300. Fuel flow is about 15 GPH.
At 105 seconds leaning begins. By 120 seconds FF is down to 10 GPH with the throttle still at WOT; RPM is actually climbing. EGTs spike to a ballpark of 1450-1500, peak or very close (the EGT curves are flattening). At 125 seconds or just after, #2 fails.
Jean is at 2832 MSL so let's assume 4000 feet on downwind. The RPM and standard day pressure would suggest something over 80% power, maybe 85%. Leaning to peak was, mmmmm, very aggressive.
Check for valve sticking. A stuck valve that does not open can blow the supports.
Check the push rods for any bending by rolling them on a flat surface. Push open the valves with a heavy push with your thumb. Feel for any dragging as the valve pops open and shut.
Used to see this often on the O-200 cylinders
