wirejock
I bought the 3' LED red and white strips and two LED-Dimmers from Stein.
The instructions on the dimmer show four connections but no wiring diagram.
Gound, Switched Output, Variable Output & Input.
My guess would be 12+ and 12V- to Input and Ground then Variable output to the LED Strip. However, just to be certain...
1. What is Switched Output?
2. Variable Output? I assume this feeds the LED strip.
3. Is Ground on the LED Dimmer 12V- ground? or
4. Is Ground on the Dimmer a ground to the LED Strip? or Both?
5. What about wire? Shielded?
6. Which end of the shield should be grounded?
7. Use the shield for ground for the LED strip?
8. Anyone have a wiring schematic?
