The official recommendation from HET is to convert the original internally regulated alternator to an externally regulated one at the cost of a few hundred dollars.
Although they did not confirm that the internal regulator assembly is sensitive to heat, that is my assumption. I will admit to some level of disappointment that the expensive Plane Power alternator is not as robust as I expected.
Just proves the point... Electronics located FWF are generally a bad idea.
