az_gila
Same ole...
....actions (binning) as the silicon manufacturers have been doing for years when they can't control a process accurately....
I first saw this in action at Signetics in the late 70's watching them make op-amps. The good ones with a low offset cost a lot more, but came off the same line.
These were under $2 items and the testing machine was spitting them out many a second. The output "bins" were actually 1 gallon plastic kitchen pitchers!
The final price of each part (same part number, just different "dash" suffixes) was determined by the fullness of the appropriate bin at the end of a production run...
They have not been able to figure out how to manufacturer consistent balanced combinations. What they do to overcome this is called "bining". They check each LED White component block against a standard, whether that is warm, or cool, or in between. It is then "binned" according to where it falls. Manufacturers can then order from that "bin". ....
