dorothygarcia31
I'm New Here
Dyson V8 Cordless and Shark NV752 Reviews: Which Wins?
If you are looking for a vacuum cleaner, Shark and Dyson have got you covered! They are currently dominating the market because of their excellent products. Still, the question is, which one is better?
Read More: Best vacuum cleaners in the world Thekinglive
For a proper answer, you need to determine what type of vacuum suits your needs and compare the best models from both brands accordingly.
It does sound a bit time-consuming, right?
Do not worry! We have researched for hours to bring you one of the ultimate comparisons: Dyson V8 cordless vs. Shark NV752.
Let's dive in!
Dyson vs. Shark
Dyson provides all types of vacuums, including stick, upright, canister, handheld, and robotic vacuum machines. Their cordless stick models are one of the favorites. You will probably not get enough of its small and robust motor.
Likewise, Shark has all types of vacuums in their catalogue. They also have a varied selection available on their website. These units are suitable for any modern home, including yours. Many of them make your cleaning chores much easier, with the machines ultimately bending over backwards, instead of their users!
The bottom line: Dyson cleaning machines are generally high-end items with better features and higher quality but at a higher cost. The products from Shark are mid-range ones with matching quality and price. In the end, it has to do with the features that you need. You should compare particular units to find the best fit.
We have had Dyson vs. Shark contests between specific devices of the same categories - for example, Dyson V7 Trigger vs. Shark Rocket Truepet (handheld). There are also similarities and differences between the products of the same brand - for instance, Dyson’s V8 Animal vs Absolute. In this post, we will have a closer look at the corded upright Shark NV752 and the lightweight and cordless stick Dyson V8. Which one will win?
Dyson V8 vs. Shark NV752
- Dyson V8 Animal:
- Shark Rotator NV752:
1. Shark Rotator NV752 Powered Lift-Away Truepet Vacuum
The filters of this model are washable. With its cutting-edge cyclonic technology, the filters won't get clogged fast. That is why this machine retains excellent suction power.
The device is operable as a handheld, canister or upright owing to the Powered Lift-Away Technology which allows for vacuuming under furniture. It is also maneuverable.
Though this Shark suits all types of flooring, it is ideal for carpeted houses as a result of its upright characteristics. The product is also famous as one of the top rated vacuum cleaners for laminate floors. Still, there are some other fantastic choices if your home mainly has hard floors. One of them is the Dyson V8.
As an added bonus, it comes with a mini motorized brush that is a significant enhancement from the previous units’ air-driven brush. Unlike models with these brushes, it will not become stuck or lose power.
A quick look at the features:
2. Dyson V8 Animal Cordless Stick Vacuum
This Dyson V8 Costco is one of the most popular lightweight cordless cleaning machines on the market. The battery life limits this type of vacuum, and the V8 has a better performance than most other models in this regard.
Its direct-drive cleaning head works decently on not just carpets but hard floors. With the maximum power mode, you have six minutes of higher suction for those more challenging tasks.
As the device is cordless, you do not have to unravel and plug in. Your reach will be unrestricted. Cleaning when necessary will become quicker and more convenient. Also, the hygienic dirt ejector works to drive out debris and dust safely and hygienically in a single action without touching them.
Pros:
Cons:
3. The bottom line
These are among the most popular vacuums currently on the market. They both suit pet owners as they can get rid of pet hair and fur with ease. They have versatile cleaning power and can transform into a handheld model. The active filter systems are a plus as well. The models are both quiet.
Speaking of the main differences, the Dyson V8 has a lighter weight than the Shark Rotator NV752. It is cordless while the Shark is corded. The price of the first is generally higher than that of the latter.
Though the two cleaners offer powerful suction and cleaning performance, the NV752 outperforms the V8 because it has a cord. Besides, the Dyson comes with a bit more features than its competitor. It is also more suitable for houses with hard floors.
Their warranty is another point of difference. While the Shark carries a 7-year warranty, the Dyson only has a 2-year warranty. Still, you should note that Dyson's guarantee duration is far longer than that of most other vacuum brands.
Useful Link: https://myspace.com/wikithekinglive/mixes/streammix-724002/photo/373916708
Wrapping it up
Whether to select the Lift-away Truepet vacuum or the Dyson V8 is up to your personal needs. You should consider factors such as budget, performance, pet hair the surfaces which will be cleaned, and ease of use.
Let's dive in!
Dyson vs. Shark
- Dyson V8 Animal:
- Filter: Whole machine HEPA (High-Efficiency Particulate Air) filtration system - the filter is washable
- Battery and Run Time: Li-ion battery.
- Maximum 40-minute run time (7 minutes in the boost mode)
- Charge Time: 5 hours
- Cord and Cord length (ft): Cordless
- Suction Power (Air Watts): 115 AW
- Bin Capacity: 0.54 Liters
- Weight (lbs): 5.63
- Warranty (years) 2
- Price: Check the most current price on Amazon
- Filter: Sealed vacuum technology - the HEPA filters are washable
- Battery and Run Time: N/A
- Charge Time: N/A
- Cord and Cord length (ft): Corded at 30ft
- Suction Power (Air Watts): 270AW
- Bin Capacity: 0.825 Gallons
- Weight (lbs): 15.6
- Warranty (years): 7
- Complete seal technology for locking the dust and dirt
- Three vacuum cleaners in one
- Motorized brush in lift-away
- Hard floor genie attachment
- TruePet mini-motorized brush
- HEPA filters.
- Ability to reach difficult areas thanks to the powered lift-away
- Usability on hard floors owing to the hard floor genie attachment
- Suitability for those with allergies as a result of the active HEPA filter and complete seal technology
- A powerful combination of three vacuum cleaners in one to fit different needs
- Extremely suitable for carpeted homes
- Lower price than other units in a similar category
- It is quiet!
- The filters will need some occasional washing
- As many as 40-minute fade-free suction. About 25 minutes with the attachment of the motorized floor tool. Use battery power only for cleaning
- Can be transformed into a handheld device
- Ability to clean high up and hard to reach spaces
- No cord means no hassle while moving around
- Direct-drive cleaning head with the ability of forcing its cleaning bristles deeper into your carpet, removing more dirt
- Two-powered heads along with specialised tools
- Wall mount for effortless storage
- Hygienic dirt ejector
- Two-tier radial cyclones
- Whole machine filtration
Pros:
- Top-performing lightweight vacuum without cord
- Easy removal of the brush-bar, effortlessly getting rid of any tangled pet hair
- Impressive Max power mode
- Hygienic emptying system
- Very Suitable for homes with pets
- Very quiet
Cons:
- Expensive (the Dyson V6 is a cheaper alternative but comes with only half the battery run time and is louder)
3. The bottom line
Wrapping it up
