From Ted's Picasa album....
The circled features are the melted/missing sections of the two brake lines. Note their location; well forward of the melted/missing floor section, and above the Ozite insulation. Given the insulation was thus
between the hot firewall base and the melted sections, I assume the insulation ignited,
then melted the lines.
Ted, did the brake lines melt anywhere else near the
bare firewall, perhaps someplace above and forward of the heat duct cross tube?
No matter really....another observation: It is possible that the fire streaming back from the cowling exit was a nice tight narrow stream, but it is unlikely. So, why did it burn through only the tunnel floor and not floor areas in either footwell just outboard of the tunnel walls?
When you heat one surface of a panel, how hot it gets is heavily influenced by how readily it can shed heat from the opposite surface of the panel. In this case the tunnel floor burned through
because it was being heated on both sides, unlike the footwell floor areas. There was a fire in the tunnel before the tunnel floor burned through.
