So I finally had some time to work on the rudder. Everything went smoothly until had to rivet the last hole on the bottom rib flange. The plans say to use CCR264ss3-2 but its too long. I followed the instructions and squeezed it to make room but the shop end is still too long and no matter what I do it bottoms out on the rivet on the opposite side. I forced it to sit flush and set it hoping that it would make room but it bottomed out on the tail of the opposite rivet and bulged out. I drilled it out and tried again, no luck. I figure if first you don't succeed try again. At that point if you don't succeed ask the the guys on VAF. Anyone come up with a solution for this or am i doing something wrong
Thanks!!
Dave
