I removed my prop and ring gear to install a new alternator belt on my O-360 with Sensenich fixed pitch prop. The re-assembly went fine as I thought I reinstalled everything in the same location. When trying to check the magneto timing, I find the timing is off by not just one or two teeth, but more like 15 or 20. I assume I'll need to take the prop off again. After I do that, what should I look for to make sure the ring gear is in the correct location during the reinstallation process? I left the magneto as it was and thought I'd ask if anyone has a suggestion or two before I do something really wrong.
Thanks, Mike
Thanks, Mike
