Dad's RV-10
I'm getting ready to replace two GDU-370's with two GDU-470's. I'll also be replacing a standalone Dynon D6 with a G5 (the only connection the D6 has to the rest of the harness is an RS-232 GPS input).
The G5 will need to be added to the CAN Bus. If I'm interpreting the original schematic correctly, the CAN Bus terminates at the roll servo at one end and the PFD at the other.
If this is correct, is it proper to simply splice the G5 CAN Hi/Lo into the PFD CAN Hi/Lo and move the termination point to the G5?
