Aviaman
I have a prop tracking issue. I have a Cato 3 blade FP on my RV-9A.
I have one blade which tracks 1/8?, or slightly greater, aft of the other 2 blades. I re-clocked the prop 60 degrees, then checked tracking again. It turned out the SAME blade was still 1/8? aft of the other 2 blades. This implies that either the blade itself is warped or that the aft mating surface of the prop is not parallel to the plane of the 3 blades. These 2 situations would cause the same blade to be aft upon the second tracking check. However, If the hub front surface itself was not parallel to the rotation plane of the crankshaft hub, another blade would have been aft upon the second tracking check.
If I assume either the 1 blade is warped or the mating surface of the prop is not parallel to the plane of 3 (true) blades, it would be tempting to shim the prop mating surface. However, I believe the mating surface should be an intimate contact across the entire surface, and not have a washer or shim causing voids and local concentrations of force. Or could a very thin shim, like paper be acceptable? Any opinions on this ?
