BGS
This weekend I got the pleasure to finally get the engine running. After a couple of cranks it started right up.
However, I cannot get the prop to cycle. Tried a few different times with no luck. I then decided to take the prop back off to see if I missed a plug or something and no luck. Everything was clear. Also when I removed the prop, oil did come out of the hub. Not much, about a cup or so.
Next was to check all the connection and they seemed fine and everything was moving freely.
Last thought maybe Vans sent me the wrong prop - governor combo. Verified that and it is good. Have the HC-2YR-1BFP Hartzel prop and the S-1-32 governor (verified from Hartzel) combo.
So still no luck. Anybody have any suggestions on what to check next?
Appreciate any input on this.
Brian
Brian
