sglynn
If you over torque a bolt can you back it out and torque it properly and use it?
For example if a bolt requires 70 ft. lbs and you accidentally go to 90 ft lbs, can you loosen it and re torque it to 70 ft lbs and all is well?
Or does over torquing require the bolt to be replaced?
thanks
thanks
