ColoradoSolar
I just received the new style Vans flap motor in my kit but I can't find any info on it. Does anyone know what the pinout is?
Does this motor require any modification to the original mounting structure, similar as the PH motor or is it a drop in type?
The manufacturer's documentation for this flap motor leaves a bit to be desired...
The thick wires are flap motor power. The thin wires are for the potentiometer. Yellow is power. Red (or Blue) is signal. White is ground.
Hope this helps!
Eric beat me to it.
The supporting engineering dept. just provide the following and I believe work is being done to incorporate it into the install documentation.
Thanks Dad.
But does the new flap motor come with the retrofit kit or is the retro kit something additional I need to get?
go here: https://store.vansaircraft.com/10-flap-motor-retrofit-kit.html
click on "kit contents" and you'll see the motor is included.
could someone please advise if the end fitting is removable on the "new" style vans actuator, ie 1/4" threads or such (like the PH unit) that the stock end piece could be removed? Thank you
just checking back if anyone has the new style to check or has installed it and knows, thank you!
