BlackRV7 said:
Yep. It's a resource hog, big time.
I have a Intel Dual Core 3Ghz, 1GB of RAM, 256mb video card and I can barely make it run with all the graphics settings on 'high'. I have to put the quality settings near the middle to get a respectable frame rate.
Unfortunately it appears that Microsoft has chosen to go the route of eye candy over improving the flight model and functionality. In more populated areas they are using aerial photos to enhance the ground scenery. It's kind of cool to be able to fly over your neighborhood in that thing and see your ACTUAL house.
The G-1000 stuff is pretty well done. I've only flown a G-1000 172 twice so my exposure to the G-1000 is limited, but it appears that MS got most of the functionality right. There are several things missing in FSX (i.e. the detailed engine page, changing map settings, etc), but overall it's fairly well done. BTW: The G-1000 is only available in the FSX Deluxe version.
Now, contradicting what I said about the flight model -- it does appear that MS has tweaked the flight model somewhat. Aerobatics in the Extra 300 was horrible...as it was almost impossible to make that thing spin. It seems more natural now to get it into a spin and do other maneuvers.
As far as the engine sounds: I spoke with one of the MS guys at Oshkosh and he said that they actually went around and recorded the engine noises from authentic airplanes for FSX. The engine sounds do seem to be much better -- particularly the Extra. There is a noticeable difference in sound.
I also like the fact that they've added tow-plane functionality for the gliders. The glider stuff is a very neat learning experience. They have a glider introduction that teaches you about thermals, ridge soaring, etc. The glider in FSX has a variometer which is neat and makes the experience very real. I've only tried the soaring introduction so I'm not sure how well it simulates thermals in other areas.
They've also added flour bombing capability and you can even try to land a Cub on the top of a moving bus a la Oshkosh.
Overall I think it's a decent purchase and is great for cold rainy days.
Almost all of the guys on the MS Flight Simulator team are pilots and fly regularly. It's neat to see what these guys are doing -- although I still think that X-plane is a better all around simulator (so does the FAA...given X-plane's certification for flight training in certain installations).
