rightrudder
Thanks for your patience with my noob electrical questions!
I'm using the Tyco circuit breaker switches pretty much as Van's intended. So I take it the "line" terminal is the hot copper buss bar, and the "load" feeds the lights, fuel pump, whatever. So with the switches in the proper orientation (amp values on end of toggle reading right side up, where up is "on"), the buss bar should run along the bottom set of "line" terminals. I've seen some pictures where the buss bar runs across the top. Were these a case of incorrect wiring?
