I am having the light speed II plus box getting hot and cutting in and out,
The box is mounted on the cold side of the fire wall it may run for several hours then it may start getting hot you can smell it getting hot and then it starts cutting in and out it never trips the 5 amp breaker, I can pull the breaker and run on the mag side and everything runs find, I have sent the box back to klaus twice and he said everything is find, he did do a upgrade to it but it still does it, we also replaced the coils. The system has about 800 plus hours on it and it worked great for several years it has ben intermit the last several hours, it has a halo sensor. I had my a&p mechanics look over also with nothing found.
Any feed back would be great help
Tim
Tim
