Radioflyer
I've removed the radio from the plane due to this issue. Made the bare minimum connections on the test bench. On powering up, the "T" light stays on continuously. Radio seems to be putting out a weak signal heard on a portable, but no voice. However, when PTT switch is activated, it transmits voice perfectly. Nevertheless, no reception because the T is on. Anyone experienced this before or any ideas before taking to avionics shop?
--Jose
PS-Earlier I had discovered one of my aircraft mic jacks had tangs that were bent and touching. Could this have ruined the radio's transmit/receive switch or diode?
--Jose
