Is this thing grounded?
RayJr
Hello,
This is my com cable where it goes through the floor and attaches to the antenna
Can someone tell me if this connection is grounding the shielding to the skin? Nowhere else on this coax is there a shield ground.
Thanks for the help
Hello,
Thanks for the help
Put a multimeter on it to see if there is continuity?
Exactly, check continuity between the case of the plug to aircraft skin. If it's not grounded whatever radio is connected to it probably wouldn't function.
Antenna GND
Normally the antenna is mounted with 4 screws to the aircraft skin.
This provides a GND for the antenna.
The antenna BNC connector (shield) is connected to GND inside the antenna.
Good luck
…Nowhere else on this coax is there a shield ground.
Thanks for the help
Hopefully there is an identical looking plug at the transmitter, which connects the shield to the local ground there. The coax is a transmission line; the shield must be connected at both ends.
Most antennas route the shield connection at the BNC connector to the aircraft skin by either routing the signal to the airframe connecting screws, or to a flat metal plate on the bottom of the antenna which is in good contact with the skin. If you’re having trouble you might check the bottom of the antenna where it is in contact with the skin: no paint, no corrosion, there.
