Inverted oil hoses
TS Flightlines
Advertiser
Just wanted to remind all the members using inverted oil systems, that AS Flightlines, the joint venture between Aircraft Specialty and TS Flightlines, has stainless braided, firesleeved, convoluted teflon hose assemblies for these systems. The hoses are TRUE bore -10 which is .625 ID as compared to H8794 (Aeroquip 303 and equivelent) that is .500. The conductive teflon liner is smooth bore on the ID for uninterrupted flow, convoluted on the liner OD for increased flexibility in those hard to plumb areas. Hoses pressure tested to 1000psi.
We use our hose ends made from 1 piece 2024T3 billet with NO BRAZED JOINTS. Our Stainless crimp collars, firesleeve with stainless bands and our stainless ID tags complete the assemblies.
WE make these to order to fit YOUR aircraft, since not everyone puts accessories in the same place. So if you want a lighter weight tested hose assembly, give us a call. We can help.
Tom and Steve
TWO THUMBS UP
I can vouch for the top notch quality and unmatched customer service by Tom @ TS FLIGHTLINES. 👍👍👍 Stew
