It plan just does not make sense
RV505 said:
One of the big manufactures did look at and did a feasibility study and even has produced a prototype. However, It was shelved because....
1. Because the engine would beyond the means of most experimental builders. $120,000.00
2. The quality of some of the experimental airframes that were looked at had poor workmanship and or bad airframe design and could be a future liability even though a crash would probably not be the result of the engine manufacturer.
3. The quality of the pilots that would be flying the aircraft.. The company wanted airline type training. Crash = Liabilty.
I was bummed out also but that is what I was told.
Not sure what engine maker you are talking about? There is already a bunch of turboprop engines out there being made in the $120,000 price range, at least used.
First I GOT TO SAY WHAT POOR WORKMANSHIP ARE YOU TALKING ABOUT? I am sorry, I don't believe that's the reason engine manufactures choose not to make more small turboprop engines. It is not practical from and engineering or economic standpoint. Why not a turbine lawn mower engine? There is a cut off where a Turbine pays for it self. The key factors are utilization and HP. When I say utilization I mean commercial level use, not 100-150 hours a year, but 70-80 hours in a week. Also reliability is key. If your engine is a no go on Sunday for your breakfast fly in, so what. Ground a plane with 220 folks or overnight cargo, that's a big deal.
The issue is a 200 HP turbine is in competition with a piston engine. There is no comparison in costs. Above 350-400 HP turbines becomes cost effective. I do not think the Innodyn economics will ever work out. Sorry.
You can get +600 SHP Walter turbo prop (PT6 clone) used for $40k TODAY! Have it overhauled for $20K-$40K and there you go. Here is a short list of small turbines used in fix wing aircraft at one time or another I would consider:
I think the Allison 250 (now RR) is used in the Beech Bonanza turboprop conversion. The Garrett was all over the place in regional turboprops before the Regional jets. I flew the Metroliner IV with the TPE331. The PT6 is the most famous and best known in the King Air. The Walter is a cheap PT6 clone from Eastern Europe.
All these engines can be found for less than $120,000 used. No RV I know of can use a 600 HP engine. The dream of a cheap 200 HP turbine is just that, a dream. Once you get into burner cans, turbine wheels, bearings, gear box, prop control, fuel controller and all the other things to make it work, it will cost as you say $120K, wheather it's 200HP or 600HP. What Innodyn has is a very stripped down engine with very simplified fuel control and electric MT prop? No torque read out? I mean it's too simple.
The smallest turbine with a gear box and prop controller I think is the Allison 250, the lowest HP version is 350HP, but typical is 420-450 HP and it goes up from there. Yes it sucks fuel like a college coed sucks up alcohol on spring break.
YOU NEED AN AIRFRAME TO USE 600 HP. Two kit planes doing that today is the
Lancair PropJet and the utilitarian
Comp Air. These planes are available today, but you are well into the 0.3 to 0.5 $mil range, typically to finish a turbine Lancair or Comp Air project (see this months "Kit Plane").
Turbine development is in industrial, military, new commercial airliner engines, such as the Boeing Dream Liner and little turbofan engines for entry level business jets. P&W of Canada took over where Williams Jet failed to meet goals on the new Cessna Mustang B-jet with their new PW615F. I think Williams also dropped off the Eclipse, which also went P&W. Williams Jets where going to revolutionize the cheap turbofan with innovative manufacturing? I would love to have one of those little 1000 lb thrust jets on a little sport plane.
Hummm Javelin?
Turboprop days are numbered or already gone. Yes turboprops are practical and work for special applications, but most want Fan jets. NEW engine technology
(FJ33) is towards turbofans, not turbo props. Don't get me wrong the C-130 and King Air are great planes, but how many commuter airlines are using Turboprops? Not many. Most have long gone to Regional Jets. Passenger just like them better, but for short haul the turboprops are still fine.
The Innodyn is not in the same class as existing turboprop engines. I consider the Innodyn a toy, not a serious engine, so lets not have Turbine envy. Lets say it together, I LOVE MY PISTON ENGINE. PISTON ENGINES RULE. EMBRACE YOUR PISTON ENGINE. I would rather have and engine that Sucks, Squeezes, Bangs and Blows than just Suck, Squeeze and Blows.
