I am trying to wrap my head around the relationship of ignition timing and its effect on EGT/Oil temp, this is on a IO390 engine with Electronic ignition advancing the timing and at around 4-5k AGL, so not high up.
Some tests has shown little effect of advancing beyond 23-24 BTDC at these level altitude. My test shows when I change my advance from a max of 24 BTDC to 30, I see a slightly higher oil temp but lower EGT (not touching the Manifold or mixture), I also pickup one to two knots, more often two.
Just though if some smarter people than me can break down what is happening here, cause and effect
