So after checking/ re timing my magneto to 25 degrees, and my lightspeed plasma (with hall effect sensor)... I went to take off was down significantly on power.. long story short, I timed the lightspeed 25 degrees too far advanced!! (Brain fart in setting it up with the engine in the same position as timing the mag)..
Anyway,, what do you think the odds are that I damaged something? In total I ran it at full power for about 30-45 seconds tying to trouble shoot things, and played with the prop a bit (as I just had it off to replace the ring gear and alt belt) and the mixture...
I set the electronic ignition back to the correct position, and it seems to run decent.. but.. time will tell I guess
