az_gila
Some comments...
This seems to conflict with Gil's posted document, Milt. I wonder which is correct?
The document I posted is their guideline and task description...
Also, once you hand them your license and they start to walk away with it, then what? You are effectively grounded unless you start an altercation or until an attorney gets it back for you.
Another "what to do in a ramp check" document I read mentioned "showing" your license, but not "giving it" to the inspector. Then it can't be construed as a surrendering of the document - however, this seems difficult in a real life situation...
azrv6 wrote" "Joe wrote : I was a little taken back when he asked to see the date for the weight and balance data, though. In retrospect, I guess I shouldn't have been, as 30 years ago I was taught that it must be current.
So, I'm curious why he would ask for the date for the weight and balance. Maybe that was just his way of asking to see the w&B. Or, unless there might be some future access to the aircraft logs and a determination made if the w&B was properly current at the time of the ramp check."
The W&B date is probably connected to the need for a current Equipment List in a certified plane. This list keeps track of changes that affect W&B, and while it's not explicitly on the aircraft required document list, in general it is called out by the planes POH, which is a required document.
A case came up locally were a Flight Examiner wanted an original Equipment List for a 50's C-170 before he would give a Private flight test....
He did back off eventually on the "original" bit...
