GDL39R to GDL52R questions
Planecrazy232
I know the "correct" answer to this, (read the instructions:rolleyes:) and G3Xpert has been helpful, but I could use some real world answers to these questions. I'm replacing my GDL39R with a GDL52R which is the SXM receiver.
My GDL39R is mounted vertically on the avionics subpanel. The GDL52R COULD mount in the exact spot, but the installation instructions call for it to be mounted horizontally within a few degrees of the longerons. The instructions also calls to "Cage the gyros" with the plane level, flying position.
So the questions are:
#1- Will this thing work in the vertical position, and:
#2- What does the GDL52R talk to that needs the attitude positioning?
Synthetic Vision?
I would guess that it is for synthetic vision to a Garmin portable (796, 660, 760 etc.) or the garmin pilot app. That is what the GDL39 3D does on my -7. It is
for the built in AHARS.
Figs
Anthony,
Your G3X Touch system doesn't use the attitude data from the GDL 52R in any way.
As Figs stated, the attitude data is only used by portable devices like the Aera 660/760/79X and some tablets for their 3D Vision page.
ACtC-3cdfKx6rX5l-bFNX-_Vc_7IvrDqHFIILLq59jc73ixAqp3tPBYseNNqSsv4mIPPqj22415jvBUn13W4Rgckc04iGAKGFAEa8av0gAxud6tT8orkWzqhzCWnCM2gE-ZSiRdX3NFkIhIVjklPgrUjU8E2=w360
If you don't need to use that page on those devices, you can mount the GDL 52R anyway you like.
Steve
Anthony,
Steve
Steve that’s exactly the information I needed. Thank you!
This is an old thread but I was thinking the same thing. I am planning my 52R install. It takes up a lot of space if it has to lay flat. Have you installed your unit? Any issues with the G3X?
Great news. I would rather not mount mine pointing forward and flat. Are you interfacing it with Foreflight? If so, does the the foreflight artificial horizon and everything work ok?
Jim, yes works well with ForeFlight but honestly I have not checked the AH on it.
I dont plan on using the horizon in Foreflight either. Just curious I’d it does work if I ever need it. I will cable it up and test to see how it works before mounting. I activated my SXM subscription today. I will post here after I do some tests.
I installed a GDL-52R per the instructions and use the ahrs info for an Ipad mini mounted on the right side of the panel using Foreflight. The attitude output works great for the panel mounted ipad and the ADS-B provides traffic/weather info for my G3X, GTN-650, and portable ipad.
Bruce
RV-7A (bought flying)
ATP, A&P
The mounting requirements for the GDL 52R will not impact interface with the G3X Touch. It can impact the performance of the AHRS internal to the GDL 52 (which is used to provide supplementary attitude data to portable devices). The way these work, it would probably look ok sometimes, but during maneuvering would begin to provide misleading data.
Justin
