SeanB
I?m in the process of installing my G3X Touch System. I?m planning to install the GSU25 ADHRS on the left face of my tip up subpanel.
I?m a little confused with Garmin?s mounting instructions. It says to mount within 1 degree of either the longitudinal or lateral axis of the plane. Later, there is up to 30 degrees of adjustment available.
I?m thinking I could use a square on an edge of that section of my subpanel to get a baseline. From there, I can locate the mounting holes. I?m thinking since this a match drilled aircraft, this method should get me really close.
Agree???
Thanks!
Agree???
Thanks!
