Garmin 3GX vs Amploc Key100 Hall Sensor
Dan 57
Guys, just hooked up my Amploc Key100 hall sensor which is sensing my alternator main wire.
But I'm just bewildered by the many calibration settings. Agreed, I might have missed something from the 997 pages manual...
The connections have probably made correctly, but the displayed value is way off, and the calibration page offers an array of options of which I have no clue :eek:
Anyone with the required settings at hand?
Appreciate.
  • key100.pdf
Once more thanks Matt!
The Amploc is wired as follows:
Pin 1 supply to pin 11 POS 3 Hi / +5V_3
Pin 2 ground to pin 12 POS 3 / GP 3 / FUEL QTY 3
Pin 3 output to POS 3 LO / GND
The configuration option I chose is Main Bus Apps Hall.
Now the 30.4.32.15.1 Electrical Current Calibration on page 682 of the AU manual version lists all parameters such scale factor, amps offset and so forth... no clue.
Guess i'm over simplithinking things, but since i'm using the Amploc Key100 hall sensor, as Garmin recommends, I was expecting a set of configuration settings readily available... it is only a current measuring device after all ;)
Referring to IM rev AU.
Information pg 30-196. 30.4.32.15 Electrical Current.
Connection pg 26-5.
Configuration. pg 30-197. 30.4.32.15.1 Electrical Current Calibration.
Configure for 15.9 MV / AMP signal.
Five explained settings to do.
Good luck
If this is accurate then I think you need to switch your wiring to pins 2 and 3 on the current sensor. The ground pin needs to be connected to ground, and the output pin needs to be connected to the GEA 24 input pin.
cool, thanks to both of you guys. I'll check things out at the hangar tomorrow and will report here again :cool:
Amploc Key100 Hall Sensor Bracket
RVPLASTICPARTS now makes a holder for the Amploc Key100. Allows you to wrap the sense wire around the "Donut" almost as many turns as needed. Works well and holds the connector securely in. This is an early mock-up so fit, and finish might not be as nice as current products.
Happy Holidays to all !!
