FUEL PRESS SENDER VDO
WingnutWick
Hello all,
I need to replace my RV-10's VDO fuel pressure sender. It is using a VDO 0-5bar sender but when I look up on Spruce for this sender the only one I find says "oil pressure sender" and it says in the notes:
VDO pressure senders are not to be used with any type of fuel application.
VDO pressure senders are not suitable for use in aircraft.
https://www.aircraftspruce.com/catalog/inpages/vdooilpressuresender.php?clickkey=24047
Is this just legal notes and is using this pressure sender for fuel PSI common practice?
Charles
This is the part number you are looking for at ACS.
Part# 10-06581
MFR Model# 362-001
Good luck
Would this be the same fuel pressure VDO for a carbureted O-320? I haven’t pulled my cowl yet but I recently replaced my VDO oil pressure sender and it was very hard to find the part number. I imagine it will be the same for the VDO fuel pressure unit.
The 362-001 seems to be an 80 psi unit with two connectors. Mine also has two connectors.
Never mind. Somehow I found my Dynon receipt from 2006 and their carbureted sensor package included a VDO 360 043 fuel pressure sender. My VDO oil pressure lasted 11 years and this VDO fuel that I suspect is bad lasted 12 years. I’ve had good luck with them.
