michelebrown
I'm New Here
I have installed an FT60 fuel flow transducer in my RV, but I am experiencing a constant reading of 0 on the Dynon HDX. The transducer is properly connected to the EMS-220 using the correct pins (13, 14, 15), but when measuring the voltage on the red cable from pin 15, I am only getting a reading of 7.95V. The instructions state that it should provide 12V. I suspect that this voltage discrepancy is the reason why the transducer is not functioning at all. Has anyone else encountered a similar issue? What voltage are you measuring at the transducer?
