Draker
Getting ready to fit and drill the firewall to the forward side and bottom skins. Before doing it though, I realized I had just assumed which order the parts need to sandwiched together. I could not find where in the plans or drawings it's actually called out. I originally had them stacked: Bottom skin over side skin over firewall flange. But looking at some pictures in others' build logs shows builders fitting the side skin over the bottom skin. But this leaves a gap where the side skins meet with the firewall, so that's probably not right. Which is it?
Most importantly: Where in the manual should I go to confirm the stack order? I shouldn't have to "ask VAF" for something as fundamental as this.
